laz avatar image
laz asked
Quattro not calcualting SoC
I have a system with 3 single phase Quattro 24/3000/70-2x50 that create a 3phase system. In the AC In 1 is connected the grid and in the AC Out 1 are connected the loads. The Battery of the system is an LFP Smart 25,6 200Ah and the whole system is monitored by a CCGX device. The problem is that the Quattro inverter doesn't calcualtes the SoC of the Battery and therefore is not displayed on the CCGX (always remains 0%). In the CCGX device is selected the Quattro as the Battery Monitor.
What causes that problem?
MultiPlus Quattro Inverter ChargerCCGX Color ControlSOC
@Laz
And you have the internal battery monitor on the Quattro programmed? And the correct charge settings?
laz avatar image laz Alexandra ♦ commented ·
If you mean the below parameters using the VE Configure 3 software, yes.
