jd87 avatar image
jd87 asked
Dvcc settings
Hi everyone my setup is now 4 battle born batteries that connect to a lynx power in then through a shunt to another lynx distributor on two of the legs are for two 100/50 mppt 3rd is for multiplus 4th goes to another shunt where dc loads are connected. What I’m trying to do is limit charge current to 100 amps from all devices if I enable dvcc charge current limit and turn off everything else will it limit the overall current to 100amps? I have multiplus set to 80amp charge current and when I get full sun the current shoots way up to 170ish amps. Thanks everyone for the help
cerbo gxmultiplus ve.busDVCCcharge current limit
nickdb avatar image
nickdb answered ·
If you don't have feed in enabled and all devices are wired to the GX, yes it will limit charging.
