remmy avatar image
remmy asked
Is there a Documentation that define what each column name in data export from VRM mean?
timestamp Africa/Lagos (+01:00)
Gateway [0] VRM Log time offset
Gateway [0] ESS Scheduled Charging
Gateway [0] Grid setpoint
Gateway [0] Relay 1 state
Gateway [0] CCGX Relay 2 state
Gateway [0] Relay 1 function
Gateway [0] Relay 2 function
VE.Bus System [261] Phase rotation
VE.Bus System [261] Input voltage phase 1
VE.Bus System [261] VE.Bus custom name
VE.Bus System [261] Input current phase 1
VE.Bus System [261] Input frequency 1
VE.Bus System [261] Input power 1
VE.Bus System [261] Output voltage phase 1
VE.Bus System [261] Output current phase 1
VE.Bus System [261] Output frequency
VE.Bus System [261] Output power 1
VE.Bus System [261] Voltage
VE.Bus System [261] Current
VE.Bus System [261] Active input
VE.Bus System [261] Active input current limit
VE.Bus System [261] AC Input 1 Current Limit
VE.Bus System [261] AC Input 2 Current Limit
VE.Bus System [261] AC Input 1 Current Limit Adjustable
VE.Bus System [261] VE.Bus state
VE.Bus System [261] VE.Bus Error
VE.Bus System [261] Switch Position
VE.Bus System [261] Temperature
VE.Bus System [261] Low battery
VE.Bus System [261] Overload
VE.Bus System [261] Temperatur sensor alarm
VE.Bus System [261] Voltage sensor alarm
VE.Bus System [261] High DC Ripple
VE.Bus System [261] Temperature L1
VE.Bus System [261] Low battery L1
VE.Bus System [261] Overload L1
VE.Bus System [261] High DC Ripple L1
VE.Bus System [261] Temperature L2
VE.Bus System [261] Low battery L2
VE.Bus System [261] Overload L2
VE.Bus System [261] High DC Ripple L2
VE.Bus System [261] Temperature L3
VE.Bus System [261] Low battery L3
VE.Bus System [261] Overload L3
VE.Bus System [261] High DC Ripple L3
VE.Bus System [261] Charge state
VE.Bus System [261] Ignore AC input
VE.Bus System [261] Ignore AC input 2
Battery Monitor [260] Voltage
Battery Monitor [260] Starter battery voltage
Battery Monitor [260] Current
Battery Monitor [260] Consumed Amphours
Battery Monitor [260] State of charge
Battery Monitor [260] Time to go
Battery Monitor [260] Low voltage alarm
Battery Monitor [260] High voltage alarm
Battery Monitor [260] Low starter-voltage alarm
Battery Monitor [260] High starter-voltage alarm
Battery Monitor [260] Low state-of-charge alarm
Battery Monitor [260] Low battery temperature alarm
Battery Monitor [260] High battery temperature alarm
Battery Monitor [260] Mid-voltage alarm
Battery Monitor [260] Relay status
Battery Monitor [260] Deepest discharge
Battery Monitor [260] Last discharge
Battery Monitor [260] Average discharge
Battery Monitor [260] Charge cycles
Battery Monitor [260] Full discharges
Battery Monitor [260] Total Ah drawn
Battery Monitor [260] Minimum voltage
Battery Monitor [260] Maximum voltage
Battery Monitor [260] Time since last full charge
Battery Monitor [260] Automatic syncs
Battery Monitor [260] Low voltage alarms
Battery Monitor [260] High voltage alarms
Battery Monitor [260] Minimum starter voltage
Battery Monitor [260] Maximum starter voltage
Battery Monitor [260] Discharged Energy
Battery Monitor [260] Charged Energy
Tank [20] Tank level
Tank [20] Tank remaining fluid
Tank [20] Tank status
System overview [0] #1 Low SOC; discharge disabled
System overview [0] #2 BatteryLife is active
System overview [0] #3 Charge disabled by BMS
System overview [0] #4 Discharge disabled by BMS
System overview [0] #5 Slow charge is active
System overview [0] #6 Charge disabled by user setting
System overview [0] #7 Discharge disabled by user setting
System overview [0] AC Consumption L1
System overview [0] Grid L1
System overview [0] Genset L1
System overview [0] Voltage
System overview [0] Current
System overview [0] VE.Bus charge current
System overview [0] Battery Power
System overview [0] VE.Bus charge power
System overview [0] Battery SOC
System overview [0] Battery state
System overview [0] Battery Consumed Amphours
System overview [0] Battery Time to Go
System overview [0] DVCC Multiple batteries alarm
System overview [0] GX Error #48 DVCC with incompatible firmware
System overview [0] AC-Input
System overview [261] Grid alarm
Temperature sensor [23] Temperature status
Temperature sensor [24] Temperature status
VRMvrm advancedvrm logging
Alexandra avatar image
Alexandra answered ·
@Remmy
No there isn't.
It is fairly self explanatory - it defines what device is sending the information to the VRM in one column and the parameters of the reading in the other
So system overview [number in brackets is the VRM Instance/register] and "xxx" is exactly what it is. i.e. frequency is obviously the frequency...
You see different things for different systems depends on the components in it.
