hybridizd avatar image
hybridizd asked
JBD/LLT BMS
Hello
I have two 48V batteries wired in parallel. both running JBD/LLT BMS
I have connected the host battery to the Cerbo GX via RS485
On the Cerbo GX it is showing up as a Pylontech battery, which is definitely not.
I have installed DBUS-SERIALBATTERY driver following instructions from https://louisvdw.github.io/dbus-serialbattery/general/install/
Rebooted the Cerbo GX and still showing as Pylontech BMS not LLT/JBD.
Looking for some assistance as I may be missing something?
Thanks
cerbo gxLithium BatteryBMS
@hybridizd
Alot of BMS manufacturers use pylontec bases. Not sure if that is true for JDB.
Are you not using can? For the connection to the Cerbo? And is it plugged in can or BMS can port?
hybridizd avatar image hybridizd Alexandra ♦ commented ·
RS485 port on JBD/LLT BMS battery to BMS-CAN port on Cerbo
hybridizd answered ·
Thanks for your reply
