aviatorhh avatar image
aviatorhh asked
EM540 on VE.bus (RS485)?
I have purchased an EM540 for our 3-phase MP/II ESS. It has not arrived yet. It has to be connected via RS485 to our Cerbo GX. I read about a RS485/USB adapter. The VE.bus on the Cerbo GX is already a RS485 bus (MP's on it). So why not just crimp a cable instead of using USB?
Please clarify.
Thanks
Nicholas
Energy MeterVE.Busrs485
aviatorhh answered ·
According this https://github.com/victronenergy/venusgx-hardware/blob/master/VE_BBB_Cape_v0.80_released.pdf the VE.bus looks as if it has RS-485 in it. The SN65HVD72 seems to be a driver for RS-485.
Has anyone tested it?
EDIT:
This document clarified it: https://www.victronenergy.com/upload/documents/Technical-Information-Data-communication-with-Victron-Energy-products_EN.pdf
In fact it is RS-485 but the protocol running over the line is MK2/MK3 which I doubt the EM540 is speaking. So I guess a USB/RS-485 adapter is indeed needed.
VE.Bus isn't standard RS485. You can't connect the EM540 to the VE.Bus, you need to use the RS485 to USB adapter.
What is VE.Bus?
Energy Meter Selection Guide
