Hi. Is it possible to connect ET112 to Cerbo with 50 metre rs485 to usb cable
120 ohm at each end ?
Hi. I connected a usb to rs485 cable to cat5e over 50m then connected it to the et112. No resistors. It works perfectly. That is used for a grid meter. I also have the same connection but over 2m to connect a pv inverter also works perfectly.
@Darrencham hi, may you help me with some pictures of the cable connection please? I'm planning to install an ESS system using ET112 as a grid meter (Zero Feed In Electrical Company Regulation). In ET112 manual read some code color table on 3 pairs (Orange Data+, Yellow Data- and Black GND), did you connect cat5e to each color twisting cables for extension (50 meters)? or use some special tools/connectors? Thank you for your feedback, regards!
BF87640A-9622-468D-AE42-0E82F73B1FE3.jpegImage Caption
hi. My connection is for ess grid meter et112 to rs485 to usb on a cerbo gx the cat 5e cable goes directly into the Et112 and a small cat 5e in-line Coupler links the wires to the rs485 to usb connection only 3 wires are connected ignoring twisted pairs as long as the colours used are the same in the et112 as connected to the rs485 cable it does not matter which colours are used. Hope this helps. Good luck
28 People are following this question.
