donroberto avatar image
donroberto asked
temperatursensoren voltage range
viessmann gas boiler + solar thermal on the roof. Like to induce the temperature sensors into the victron system.
The temperature sensors from solar thermal on the roof have 1,5V,
on the analog I/O from CerboGX i measure the voltage aproxx 4,5V
are there differences or can i just connect it?
If that works, I can connect the temperature sensor to the CerboGX in parallel or change the temperature on the boiler?
Thnak you
Roberto
cerbo gxvoltageTemperature Sensor
