cbnw avatar image
cbnw asked
CERBO GX FURUNO TZT2 & TZT3 NETWORK Marine MFD GX integration
Has anyone successfully integrated a CERBO GX unit to a FURUNO MFD that is in a 'Furuno mixed network' configuration (TZT2BB & TZT3) ?
  • I recently connected a CERBO GX unit (ethernet LAN port) to a FURUNO MFD and the Victron page works fine on the TZT3 MFD. (All Furuno software levels are current as of 9/1/23)
  • Unfortunately, the victron page on the TZT2BB is inoperable and the "Victron Icon" appears as "QNN" and if you select it an IP address error message is generated.
(Per the Victron "Furuno MFD Integration URL = the TZT2BB is compatible).
(I contacted Furuno support and they have not tested this configuration).
cerbo gxsystem integrationmarine mfd app
