Patrick avatar image
Patrick asked
What is the proper Multiplus-ii 24/3000/70 configuration with Victron 24v Lithium batteries?
When I got into VE Configure and set my batteries to Lithium, I get a low battery warning (solid RED) on my Multiplus-ii. When I set it back to "defaults" it goes away.
This feels like an FAQ, but I can't find the answer, what have I missed?
My system:
  • Multiplus-ii 24/3000/70, Firmware 506
  • Lynx Smart BMS, Firmware 1.06
  • Cerbo GX, Firmware 3.01
  • MK3-USB-C
My config export is attached.
Multuplusii_24v_Lithium.txt
Thanks so much!
Multiplus-IILithium BatteryVEConfigure 3
Don't use the preset "with VE.Bus BMS" because you don't have a VE.Bus BMS.
Patrick avatar image Patrick commented ·
That did it, thanks @Matthias Lange - DE.
Very odd that I have to pick the option which doesn't say "Victron Battery". Maybe a new entry with Victron Battery, Lynx Smart BMS would be helpful.
dmsims avatar image
dmsims answered ·
You do not say what type of battery/batteries you have
If 3.2v cells then 28.40V is a little high and of no real benefit
This is "with Victron 24v Lithium batteries", Lithium Battery Smart 25.6V 200Ah.
