ovaron avatar image
ovaron asked
Multiplus 2 48/3000 GX Lifepo4 Battery values
Hi.
I got 2 5kwh lifepo4 batteries and at the moment I am struggeling with translation of values names inside of batteries manual and victron value names.
Those values are inside of the battery manual:
1. Overvoltage disconnect voltage -----57.6V
2. Charging limit voltage ----58.4V
3. Overvoltage reconnect voltage -----53.5V
4. Balanced charging voltage -----56V
5. Increase the charging voltage
6. Float charging voltage -----54.0V
7. Boost reconnects charging voltage
8. Low voltage reconnect voltage -----48V
9. Low voltage warning Reconnect the voltage -----48V
10. Low voltage warning voltage -----45V
11. Low voltage disconnect voltage -----43.2V
12. Discharge limit voltage -----40V
Can you help me which values I should enter in VEconfigure with ESS to which victron field?
Thanks in advance.
Multiplus-IILithium BatteryVEConfigure 3
@ovaron
Probably the low voltage warning level of 45v
ovaron avatar image
ovaron answered ·
What I have interpreted so far from the values in the documentation would be the following Victron settings. Are these okay or do I break the batteries with it?
DC input low shut-down:43.2V
DC input low restart:48V
DC input low pre-alarm:45V
Absorption voltage:56V
Float voltage:54V
Charge current:50A
Sustain voltage:40V
JohnC avatar image
JohnC answered ·
Hi @ovaron
Maybe your batteries are in this list?.. https://www.victronenergy.com/live/battery_compatibility:start
Even if not you may learn a bit from reading through what's involved with some of them.
