Does anyone know if a mains failure alarm can be connected to the relay outputs of a multiplus 24v/5000/120A inverter/charger? Or alternatively from the relay connections of the color control GX display panel?
Stuart
Stuart
Hello Stuart,
This is possible by using the Programmable Relay of the Assistants functionality in VEConfigure.
You will need to create two programmable relay assistants, one to open the relay and the other to close it.
All steps required to get to this point are in the manuals above;
Here are the steps from there specific to your request:
2nd programmable relay
You will need to test it yourself of course. Please report back if you get it working or not.
8 People are following this question.
