pellkartoffel avatar image
pellkartoffel asked
AC Current sensor with Multiplus -II and Cerbo GX
I have a Multiplus-II 48/10000 connected to a Cerbo GX via VE.Bus. I also connected the 40A AC current sensor to the AUX 2 input of the Multiplus and added the corresponding assistant via VEConfig exactly as described in this thread:
https://community.victronenergy.com/questions/48705/multiplus-ii-gx-current-sensor-for-grid-based-pv.html
Unfortunately, the current sensor does not appear in the Cerbo GX Terminal. Is there any additional configuration required for it to show up? The documentation (found here) mentions selecting "the correct profile on the GX Device" under "Settings -> System setup" but I can't find any such setting.
Any input would be greatly appreciated!
Multiplus-IIcerbo gxsensor
stoneleigh avatar image
stoneleigh answered ·
Hi, I had the same problem (but using temp input), I found the answer here https://community.victronenergy.com/questions/139552/how-to-test-ac-current-sensor.html
The cerbo needs to be re-booted : settings/general… !
