matthias-x avatar image
matthias-x asked
Multiplus MK3 communication for ESS
I´m trying to create my own ESS system with Multiplus 2 and own control software. I just want to tell the device that it should take or feed xxx Watt to/from grid.
Here is my setup:
  • Multiplus 2 3000W 48V
  • MK3-USB Interface
  • Simple serial pc tool in order to see the communication (HTERM)
I already read the documents:
  • ESS mode 2 and 3
  • Interfacing with VE.Bus products – MK2 Protocol
What I´ve done:
  • Set the grid to AN4105 – Internal NS
  • Installed the ESS assistent 017E
In general, I can communicate with the device. I can read DC Info, AC Info.
From the documents above, I think I have to find the RAM ID of the ESS assistant and then just write the set point. Here is what I get (without CRC):
Read RAM ID 128:
05 FF 57 30 80 00 → 07 FF 57 01 00 89 5C
means: Assistent 0000 with 1 RAM ID? (and ~230V AC)
Read RAM ID 130:
05 FF 57 30 82 00 → 07 FF 57 54 00 89 5C
means: Assistent 0005 with 4 RAM ID? Is this the ESS assistent? The manual says that it has only 2 RAM ID? Or do I have to look for the installed 017E assistent?
Read RAM ID 135:
05 FF 57 30 87 00 → 07 FF 57 A1 00 89 5C
I´ve checked also higher RAM ID, but they bring a 00 00.
When I try to set a RAM adress I get a 0x80 error:
Set RAM adress 128+1:
05 FF 57 32 81 00 → 04 FF 57 80 00
Set RAM adress 130+1:
05 FF 57 32 83 00 → 04 FF 57 80 00
write Data to RAM ID (setpoint 200W):
05 FF 57 34 C8 00 → 04 FF 57 80 00
Where is my mistake?
Thank you.
Multiplus-IIcommunication protocolMK3
matthias-x answered ·
I´ve got new information:
This link helps:
https://community.victronenergy.com/questions/129947/problem-implementing-the-example-364-from-the-ess.html
- It seems that I have to power off and on the device after I´ve used the victrion control tools. After restart, I didn´t get the 0x80 error.
- The setpoint command has to be repeated every several seconds (maybe 10?), otherwise it will switch to zero.
@ victron
please update you´re documents. I lost a day with googling and playing with the commands.
The ESS assistant seems to have now 4 RAM ID, the manual says just 2. what are the other for. Can you please describe the current meaning of the ID. There is also no information in the changelog.
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
