Is VRM down? It says I have no active installations
Hi all, thank you for the report; our monitoring noticed issues approx 45 minutes ago; and since then then we're working on it.
I'll make sure we'll keep you posted here.
all should be back to normal. If its not - please let me know by adding a note here.
All "State" grahps - MPPT State, Solar Charger Relay State etc... - are showing void here.
Hi, yes that was temporary. Those state graphs cause enormous cpu load on the databases. And that is what the problem is: server overload.
We’re expanding all clusters; this will be a thing of the past very soon.
Thank you for your patience!
Well this morning, portal is again not displaying graphs...
Apologies, we have temporarily disabled the 'state' widgets like (ESS battery life state, and MPPT State).
This was done as a pre-cautionary measure to prevent other load issues from escalating. These state widgets take more server resources than the other widget types.
State widgets should be available again in the next 24 hours.
Hi, I am getting logged out multiple times a day. Should that be so?
Anyone else experiencing this?
Also with some clients, realtime connections will not enable, when accessing VRM.
I also had my PV-Inverter tile showing no output Power (while individual phases, as well as remote console, reported all fine).
Same here ..... was noticing some of my Advance data like VE.Bus State wasn't showing while AC inpout Voltage was and then all of a sudden data came through again......
How to change the Owner of a VRM installation
60 People are following this question.
