ghostrider avatar image
ghostrider asked
Bug - VRM Temp Unit (C/F) On BMV Widget
In VRM Portal there looks like a small bug in the Widget for Battery Summary on a BMV.
Everything is set to Fahrenheit in the profile & device, but the "Battery temperature" is still displaying Celcius value even though the unit is correct.
The screenshot below, it should be reading 59 F, not 15 F (15c==59f)
VRMBMV Battery Monitorbug report
Teun Lassche avatar image
Teun Lassche answered ·
@Ghostrider thanks, this is fixed!
ghostrider avatar image ghostrider commented ·
Thanks for the quick fix!
It looks like there still may be a small issue. For the most part, it does display right, but sometimes it likes to swap between the old way and the new way. Then on the next data update, switches back.
Almost like its not fully deployed - maybe a server in the fleet still has the old code?
