Can more than one Lynx BMS be connected to the same Cerbo GX? I understand only one would be used for the system view pages, but does it support multiple listed in the device list as it does BMVs or Smart Shunts?
Hi, yes it does
Hi @banana,
You can select this manually or let the system select it automatically (default).
To do this, go to the DVCC menu and scroll down to the bottom of the menu where it says "Controlling BMS". At this menu item, press the spacebar to select the BMS to use for DVCC.
Note that this is a new feature that will only be released with version 3.00 and is not yet included in the last release version 2.94.
You can also find more information on beta testing in the beta test thread.
Victron VE.Bus BMS product page
59 People are following this question.
Does the Lynx Smart BMS really only report start/stop charging to the Cerbo GX?
Cerbo GX, DVCC and combined charging from Multi, MPPTs and alternator. How measured?
Lithium Battery miniBMS / VE Bus BMS / BMS 12/200 - Low temperature protection available?
