imran avatar image
imran asked
Charge Settings
Hi, I'm looking for some advice.
The following system is managed by the Pylontech BMS.
48V 3000W MultiplusII, Smartsolar 150/35, Cerbo GX, 2 x Pylontech US3000C.
I can confirm DVCC is turned ON.
I was told I should manually set the pylontech recommended parameters in the multi and charge controller in the event they lose communication with the Cerbo. Do I turn OFF DVCC, set the parameters and then turn it ON for the BMS to takeover?
BMSPylontechDVCC
kevgermany avatar image
kevgermany answered ·
From memory, yes, disable DVCc, set the parameters, then re-enable and set the DVCc values.
Not sure if you're aware, but there's a setup guide for Pylontechs. https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
imran avatar image imran commented ·
Appreciate it!
