Hi! me and my partner are planning our electrical system in our campervan. Does this look okay? Does anyone know what diameter of cables are needed? We are both newbies at this :P !![]()
You need to compute your loads in amps.
Your loads, in amps, will help you decide your fuse sizes.
Your fuse size, determines your minimum wire size.
The wire length ( voltage drop ) may require even larger diameter wire.
Are you going to have a communications wire and/or a control panel?
The schematic looks OK.
I don't see a BMS, so best add it if the batteries don't have them built in.
I assume you have a proper RCD between AC in and the multiplus.
The AC in earth must go to the vehicle body, not shown.
AC to consumers must go through a consumer unit with suitable breakers, tcd/master switch
I assume there's a fused distribution system for DC loads.
I suggest adding a GX device, such as a Cerbo to control and monitor the system.
Not sure where you'll be going, but some European AC supplies have Neutral and Line reversed. Make sure you have a way to check and a reversing connection if appropriate.
For current/ cable sizes, treat every run independently using one of the online calculators.
39 People are following this question.
