I just added a VTAC Battery to my System. Everything works out great, the Battery is recorgnized as LG Resu. The only Problem is the current flow direction in venus charge is shown with - and discharge as +. Is there a way to change this?
I assume it has comms with the GX?
The problem is in the battery not with Victron. They probably have some voltage sense wires backwards on their shunt if they have one internally.
A similar thing happens when a Victron BMV is installed backwards.
I have seen that happen a few times with the 'not so main stream' batteries.
Yes, all other parameters are transmitted correct.
It is not the sense wire, the current direction on the battery display is correct, it is a driver/bms/config problem.
I also got myself a V-TAC 10kWh battery for testing. You could also chime in on my thread if you want. On the issue, did you use the included cable to connect to the GX device? I will be setting mine up tomorrow and will let you know how it goes.
Does the VenusOS calculations work the way it is set up now (with the + and - reversed), or does it loose control of the battery SoC this way? But, then again, SoC is reported by the battery, since this is a battery managed system now, I guess?
By the way... 53.1V at 97% SoC and almost idle state seems a bit on the low side... How many times has the battery fully charged?
Hi, I am having the same problem, battery shows reversed amps from the VRM portal, SOC and Voltage works. Adding batteries in parallel also works. You just have to change the address setting in the dip switches.
Mine works on the 02 Inverter code instead of the 04 as stated in their manual.
The original cable does not work, you have to make a corrected cable.
39 People are following this question.
