christianf avatar image
christianf asked
is bluetooth GPS supported with the Cerbo?
I only found an old thread to this topic here, but looks this is outdated.. https://community.victronenergy.com/questions/55757/venus-gx-a-bluetooth-gps.html
Does the Cerbo support Bluetooth GPS devices? As there are now the Ruuvi and the Mopeka devices feeding in data via BT, are there any GPS devices that are also supported for this? As I have to place a BT stick to the Cerbo and need one USB for USB-to-VE-direct, there is no more port left for a USB GPS, and if I could avoid an active USB hub, I'd be happy :)
Thank you!
cerbo gxBluetoothgps
