After a recent app update my MPPT 100/50 cannot be discovered by the Victron Connect app. I have disconnected from the battery and solar panels and re-installed the app on my iPhone 6 to no avail! Any new ideas to help would be great.
Perhaps the problem is with the Bluetooth permission in iOS. We have had a similar issue where the bluetooth permission was removed from VictronConnect. You can check this in the following manner:
With kind regards,
Thiemo van Engelen
I have had a similar issue, and the only way that I was able to fix it was to disconnect the charger from the battery at night and then reconnect.
I have the same problem with both my mppt controllers one is a 100/30 and the other is a 100/50. Every morning they both have to be disconnected and re connected before the Victron connect app can find them. They are both working fine but just not available to connect to, there must be a way to fix this, has anyone had any luck with this issue as i can see many comments about it, but no solutions apart from disconnecting and reconnecting them.
You may have to create a Victron Connect service report.
There are quite a few reasons, sometimes phone related sometimes hardware/firmware related.
I Click on "create service report" and it makes a service report and attaches to an email, but who do i send it to, i can not copy or download or even open it, and it does not have any info on where to send it
Cheers Dann
When creating the service report, it should be possible to select "Save to Files" instead of sharing it via the mail client. When "Save to Files" is used, the file is stored on the phone and it can then later be attached to a comment/answer here on this forum by pressing the upload file icon in the editor of the comment/answer.
Kind regards,
Thiemo van Engelen
Hi Thiemo
When i Select service report, i get no options at all, it goes straight to Email as a Attachment.
Im using Victron Connect v5.59 on an Android phone.
Cheers Dann
My bad... I was under the impression that you were using an iPhone. There are also possibilities to do this under Android, for example using the app "File Manager" https://play.google.com/store/apps/details?id=com.alphainventor.filemanager
But I think the service report will not tell much, just that it is not visible. Do you have something like a Cyrix-Li Charge installed that disconnects the MPPT from the batteries every night?
And does it indeed occur every day or are there also days that this does not happen?
Kind regards,
Thiemo van Engelen
Hi Thiemo
Thanks for looking into this for me.
It happens every morning both mppt controllers have to be disconnected and then reconnected for them to be accessed by the Victron connect app, it seems that have to disconnect them then reconnect the 100/50 first then the 100/30 second and then they are both available for the app, if i don't do this in the morning i cannot connect to them, but they are still working OK just not visible for Victron Connect app.
Just wondering if the Victron Argofet battery isolater would be interfering with them
Cheers Dann
Do you also have the energize input connected of the Argofet?
And do you perhaps have the system connected to a GX product like a Color Control GX or Cerbo GX? Or do you perhaps own a VE.Direct cable?
Kind regards,
Thiemo van Engelen
Hi Thiemo
I have the Energize input of the Argofet connected to the bus bar the Mppt controllers connect to but it hasn't made any difference, I do not have a Colour Control or Cerbo GX, but i do have 2 VE.Direct Cables available that are not connected.
Cheers Dann
My mistake, but I meant a VE.Direct USB cable. Do you perhaps have one of those? Otherwise I would like to know whether switching the BLE off and on via the VE.Direct port makes the SmartSolar visible again.
Furthermore, I would like to do some testing to see whether the Argofet could cause this behavior. This however takes a while.
Kind regards,
Thiemo van Engelen
Enable the Bluetooth on your phone.Open VictronConnect, and scan: On a phone or tablet, pull down the screen, or tap the refresh button to initiate a scan.
H Thiemo
Not sure what you mean by turning the BLE off and on via the VE Direct port
Cheers Dann
When you have a VE.Direct USB cable, you can a laptop (or android phone using USB-OTG/USB-C cable) to the VE.Direct port of the SmartSolar, run VictronConnect on the laptop/phone/tablet (windows/MacOS/Android) and VictronConnect will connect to the SmartSolar via the VE.Direct USB cable. Then in the "Product info" menu of the SmartSolar (Settings->three dots top right corner->Product info), there is a toggle "Bluetooth enabled". With this you can switch the Bluetooth off and on again. I was wondering if this makes the SmartSolar visible via Bluetooth again. But this requires a VE.Direct USB cable.
Kind regards,
Thiemo van Engelen
18 People are following this question.
