I have a generator that is connected at AC Input 1 but the generator production is under Generator. Nothing connected to AC Input 2.
So can anybody explain what is To AC Input and From AC Input?
![1680051207032.png](/storage/attachments/51115-1680051207032.png)
Hi @Alia Rahim
I believe the graphics are there more for systems that have a grid inputs rather than generators.
ie it makes more sense if replace the words AC Input with the word grid.
I believe the addition of generator graphic is new ish to VRM (I've not got a generator) but i imagine before the generator graphic was added to VRM you would just have had From AC Input showing as your generator number.
However now the generator graphic is in VRM and your system is configured with that and not with a grid input the to/from AC Inputs are not needed/redundant in your setup.
Is there any way to disable the To AC Input and From AC Input?
How to change the Owner of a VRM installation
48 People are following this question.
