petrikyntomaa avatar image
petrikyntomaa asked
Strobe lights in cabin when charging
The cottage has solar electricity via an inverter 230V. If the battery level gets too low, I charge them with the Blue Smart IP22 Charger 30A charger, in this situation the entire solar system with inverter is separated from the cabin's electrical system with a mains changeover switch and the generator is used. When I plug the charger into the socket while the generator is charging, the cabin lights start flashing like strobe lights. Where could the problem be?
chargerGeneratorerror
anthony avatar image
anthony answered ·
Are the lights led or other? What size if the generator?
petrikyntomaa avatar image petrikyntomaa commented ·
Lights is led 230V and generator is 2500W/230V
assyntdavid avatar image
assyntdavid answered ·
Is the LED on a dimmer switch? I can a similar issue when I was charging the batteries via the Multi 2 using a generator - until the dimmer blew. All dimmers now replaced by simple switches!
Regards,
David
No dimmer
Chargers.
MultiPlus Generator FAQ
GX - Generator auto start/stop
Automatic Generator start/stop
 Hybrid Generators
Virtual switch - Generator start/stop
