anthony avatar image
anthony asked
Cegasa SolarGreen configuration with Cerbo GX
Has anyone successfully configured a Cegasa Solargreen battery system to a GX device.
I cannot get the Cegasa to appear on the device list of the Cerbo?
The system consists of 2 X Cegasa Solar Green 5160, 1 X TCC CAN, 1 X Cegasa Hub Com, 1 X Multiplus II 48/3000, 1 X Cerbo GX, 1 X GX touch. ESS system.
The Firmware version on the Cerbo is 2.93. The TCC CAN is not a v02 - does it need to be?
I have tried a number of TCC CAN unit and hubs?
Please get in touch if you can help.
Lithium BatteryBMSgx device
romarub avatar image
romarub answered ·
The Victron & Cegasa article currently only lists compatibility with the eBick Ultra 175 and eBick Pro 280 models. The eNerlit SolarGreen model is not listed. Could this be the reason? Also check the settings described in paragraph 5 of the above article: "GX device configuration".
