superdavidone avatar image
superdavidone asked
Multiplus 3000/12/120 recharge up to 85% and stop.
Good morning everyone,
I have a simple system installed on my Camper.
The Multiplus 3000/12/120, combined with an SmartSolar 100/50 and an Orion 12/12/30, interfaced on a Cerbo GX together with a Smartshunt 12/500A. The battery is a 200Ah LiFePo4 with integrated BMS. The temperature and voltage sensor of the Multiplus and Smartshut are installed correctly.
The MPPT manages to bring me the recharge up to 100%, then maintain and compensate with the loads present at the moment.
The Multiplus unfortunately not.
Fast charge up to 85% after changing to float.
I can't figure out where I made the wrong settings and why if all the devices read the SOC from CerboGX it's like making an exception.
Thank you all.
HI
David
Multiplus-IIcerbo gxcharger
@Superdavidone
Possibly it is a voltage thing.
If other devices are providing power to the battery, the inverter can go to float as it is not doing anything.
superdavidone avatar image superdavidone Alexandra ♦ commented ·
Thanks for the reply Alexandra,
unfortunately it happens in the evening, when the MPPT is in stand-by.
Alexandra avatar image Alexandra ♦ superdavidone commented ·
You will have to share your settings then.
