gnagflow avatar image
gnagflow asked
How can Multiplus 1 be used to increase charge power in ESS system with Multiplus 2 and GX
Hi, I have installed an ESS system with MP2 5000VA/48V, 40kWh battery bank and 5kW PV solaredge inverter on AC-IN. I have an additional MP1 5000VA, how can i use this only as charger to increase the charge power of the system up to 5kW?
I cannot find any information resources, i know that those different models cannot be used in parallel. I know that i could set up an additional gx and make an independet addtional system, but i am looking for a solution as one system with one monitoring?
thank you for your help.
Multiplus-IIbattery chargingcharger
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
