ryzho-serge avatar image
ryzho-serge asked
Multi RS smart 48/6000/100 + cerbo + pylontech (solar not feed in loads)
Hello! I have a problem with my installation on Multi RS smart 48/6000/100 + cerbo + pylontech us5000 . Solar power don't feed my loads, without using battery. But this is problem, because i need to keep a maximum reserve battery, and not use battery cycle. The Multi RS can do this or not? Or am I doing something wrong?
Pylontechmulti rs
mr-no avatar image
mr-no answered ·
Since nobody answered up to now I will try as a customer with a Multi RS solar in usage. If I understand correctly you always want to have a full battery as long as there is grid power. Maybe you should try "ESS->ESS mode->Keep batteries charged". Once the battery is full, solar power should only feed your loads.
