kevinc avatar image
kevinc asked
Discharge battery power to grid (winter cashback events)
Today there is a cashback event where you get paid £3 for each KW that you do not used compared to your average.
With these events i have been using 100% battery power so my grid power is around zero.
Today i am thinking to export power back to the grid so that i have a negative usage.
How would i go about this do you think?
Would on the ESS settings changing the Grid setpoint from 50W to a negative number work, or is there a better way?
Multiplus-IIPylontechgrid
Alexandra avatar image
Alexandra answered ·
@KevinC
In ESS you just set feed back excess from DC in. Set your battery min in case of grid faliure down. It should feedback.
Do you have solar?
kevinc avatar image kevinc commented ·
Yes i have the G99 certificate
Yes i have solar but it is likely that there will be no solar production at the time of this event
nickdb avatar image
nickdb answered ·
The easiest way to control what and when to discharge, is to set a negative setpoint in ESS, since you may want to do this in the middle of the night when they are paying a premium for power.
You can then automate this with node red, though there are a number of improvements coming which will make all this much easier.
sharpener avatar image sharpener commented ·
<there are a number of improvements coming which will make all this much easier>
@nickdb what are you alluding to here?
kevinc avatar image kevinc sharpener commented ·
yeh nickdb i think that is what i have done
ESS / Grid setpoint, i have set this to -2000
i am doing this manually at the time of the cashback event and then i will set it back to say 50 after the cashback event.
what is node red, where can i learn about how to automate it?
nickdb avatar image nickdb ♦♦ kevinc commented ·
Go look on the modifications section. Victron has a 3 part youtube webinar that does an introduction.
