wysiwyg avatar image
wysiwyg asked
Lynx Shunt Issues
Hi All,
System working fine, and suddenly Lynx Shunt is no longer reporting the correct SOC and other info. Even the infographic is showing a feed going into batteries in the middle of the night and AC is showing a load of 96W which has always been the same as its a fridge running.
Also in devices menu, the VRM instance number is showing as 0, for all other installations its showing a number like 276 or similar. See image attached.
Had to change the battery monitor from Lynx Shunt to the Multiplus Inverter/Charger in console settings.
Any ideas on what might be wrong? faulty Lynx Shunt?
VRMBMSlynx shunt
