patrick-rynhart avatar image
patrick-rynhart asked
Toggling "Charger Only" to "On" via API Call ?
Via the VRM Webapp, you are able to set the mode of a device (in this case a MultiPlus II) to Charger Only/Inverter Only/On/Off (please see screenshot).
I'd like to be able to toggle the state of this programatically. But I can't find anything in the VRM API that allows values like this to be set: https://vrm-api-docs.victronenergy.com/
In fact the only things that you seem to be able to retrieve via the API are 'read-only' metrics and the like, there doesn't appear to be a way to set variables that you can get to via the WebApp (like "Charger Only", "Inverter Only" etc.....).
Is this a limitation of the VRM API - or am I missing something ?
With Thanks in Advance,
Patrick
Multiplus-IIVRMapi
patrick-rynhart answered ·
From what I can tell, there isn't a cloud based API call to change these settings. When you use the VRM Webapp, it looks like it's actually coming back on-prem (via an SSH tunnel ?) and ultimately publishing an MQTT message on a local GX Device.
After a lot of observations/debugging/use of strace and tcpdump etc (on a GX device), I found that I can publish to the MQTT service the following:
Topic: W/my_portal_id/vebus/257/Mode
Payload: {"value": X}
A value of 3 corresponds to "On" and a Value of 1 corresponds to "Charger Only"
