Salim Naufal avatar image
Salim Naufal asked
Inverter switched off when CANBUS disconnected
I have a Batrium BMS That is connected to the Cerbo gx using the CANBUS. The BMS has a an issue where it freezes for an undetermined amount of time then restarts normally. When it freezes for more than one minute (not sure the exact duration), my inverters turn off. As soon as the CANBUS data is back, the inverters turn on.
Is there a way to program a delay before the inverters turn off?
BMScommunication protocolshutdownbatrium
Alexandra avatar image
Alexandra answered ·
@Salim Naufal
Unfortunately you cant have the best of both worlds.
If the can is disconnected the system has to protect itself and batteries by stopping everything. So safety.....
Maybe use the inverter as the battery monitor until you can work out why it is disconnecting?
Salim Naufal answered ·
I totally agree with the protection mechanism. I was just checking if there was a way to increase the delay.
