HI,
does any one knows, if i can /should add fuses to the 16S wires? if yes how big should the fuss be? 5A is ok?
Any time you have a cable connected to your battery / cells you should have a fuse in place, should something damage the cabling.
Fuses should be rated as per balancers requirements. Cabling should be rated to sustain current that the fuse will break at.
35 People are following this question.
