Multi with old firmware on Cerbo .
Question: Which function will work and which function will not work?
As @JohnC mentioned big call. What inverter what firmware?
The Cerbo GX manual is very clear on this topic. Check out the DVCC Requirements, section Firmware version.
Minimum firmware version for a Multi/Quattro is 422. Don't use DVCC if your Multi does not meet this requirement.
You might have issues with assistants but in theory the core capabilities should work, whether or not it is tested anymore, can't tell you but the cerbo docs state supported firmware:
The earliest version of the VE.Bus devices which can be connected to the Cerbo GX is 19xx111 or 20xx111, which were released in 2007. VE.Bus firmware 26xxxxx and 27xxxxx are also supported …but 18xxxxx is not.
edit: Stephanie has confirmed the DVCC requirements so no go there.
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
54 People are following this question.
Multiplus compact Firmware Update Problem - failed at 9%
Multiplus 12/3000/120-16 and CerboGX with LiFePO4
2654 Quattro 48/8000/110-2x100 vs 2655 Quattro 48/8000/110-2x100
New batteries installed: GX Error #48 DVCC with incompatible firmware: Warning
How can I control the MultiPlus from my phone using CerboGX?
