Pascal Maag avatar image
Pascal Maag asked
How to connect two Island Log-cabins via 230Vac?
I have a Log-cabin in the Alps with 2x SmartSolar MPPT 250/100 VE.Can, CCGX, 1x Victron MultiPlus-II 48/5000, 48Vdc 9kW Batterie, 4.2kWp PV Array.
Now my Neighbor (70m Cable-Distance) would like to link in.
The Idea is to bild a separat Island System a the Neighbors Log-Cabin and link both Island-Systems via 230Vac.
Should we link both Inverters via VE.Can over the 70m distance or does there exist a solution to just use the AC-Line?
Multiplus-IIVictronConnectsystem designMulti RS
taylortops avatar image
taylortops answered ·
Research "AC Coupling". Victron have some papers on it too.
