e11enn avatar image
e11enn asked
Charging voltage MultiPlus incorrect?
So I just setup my MultiPlus 12/800/35 with my VE.Bus Smart Dongle. I set de dipswitches to
1=off, 2=on, 3=off, 4=off, 5=off, 6=off
This should give me a charging voltage of 14.7 for my AGM battery, but when I check the app it says it has a voltage of 14.10 (sometimes drops to 14.07)
I did save the settings with switching 6 on and off.
What am I doing wrong?
Also, is there a way to change settings in the app or can you only see data?
Multiplus-IIMPPT Controllersbattery chargingVictronConnect
e11enn avatar image e11enn commented ·
I did a test with 2=off and 3=on and its giving me the correct voltage. Is the manual faulty?
