ceke01 avatar image
ceke01 asked
Read com.victronenergy.vebus all Enegry register has value 0
I would like to have an overview using modbus of kwh charged from and send to the grid but when reading this registers they are all 0. (using a cerbo GX)
Energy from AC-In 1 to AC-out 74
Energy from AC-In 1 to battery 76
Energy from AC-In 2 to AC-out 78
Energy from AC-In 2 to battery 80
Energy from AC-out to AC-in 1 (reverse fed PV) 82
Energy from AC-out to AC-in 2 (reverse fed PV) 84
Energy from battery to AC-in 1 86
Energy from battery to AC-in 2 88
Energy from battery to AC-out 90
using the battery registers
Discharged Energy 301
Charged Energy 302
is not an option since i am using a can.bus connected BMS battery.
what are the other options ?
Thanks,
Ceke
cerbo gxModbus TCPvebus
ceke01 avatar image
ceke01 answered ·
Hi everyone,
Found the issue, in case someone else have the same :
I was reading the register as a signle register. It returned only the first part of the register what was equal to zero, reading the second part gives me the right output.
Nikolaus Tittler avatar image
Nikolaus Tittler answered ·
Which Scale factor do you use?
Jean Jacques de Jong avatar image
Jean Jacques de Jong answered ·
The relevant scale factors are indicated in Victron's modbus spreadsheet.
