xell1984 avatar image
xell1984 asked
Waveshare RS485 CAN HAT (B) on RP3 B
I bough this Waveshare CAN hat with both RS485 and CAN.
https://www.waveshare.com/wiki/RS485_CAN_HAT_(B)
i got the CAN working with
dtparam=spi=on
dtoverlay=mcp2515-can0,oscillator=16000000,interrupt=25,,spimaxfrequency=1000000 dtoverlay=sc16is752-spi1,int_pin=24
But not the RS485 which i need for my EM540. Any Suggestion?
root@raspberrypi2:~# dmesg | grep -i '\(can\|spi\)'
[ 7.034005] CAN device driver interface
[ 7.144451] mcp251x spi0.0 can0: MCP2515 successfully initialized.
[ 7.593323] F2FS-fs (sda): Can't find valid F2FS filesystem in 1th superblock
[ 7.608627] F2FS-fs (sda): Can't find valid F2FS filesystem in 2th superblock
[ 21.665582] can: controller area network core
[ 21.745287] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
[ 22.513880] can: raw protocol
I testet it with latest stable and Beta, but i don't know what to do. Thanks for your help!
Best Regards,
Xell1984
Raspberry PiVE.Canrs485
bathnm avatar image
bathnm answered ·
@Xell1984 Have you made sure that the overlays exists in the overlay directory (/u-boot/overlays/) If not it will not load. You may also need to add any kernel model that the RS485 might need. You may also need to check that pin 24 and 25 aren't being used as relay GPIO's within the /etc/venus/gpio file as if they are you have a clash of devices trying to use the relevant PIN.
xell1984 avatar image xell1984 commented ·
@Bathnm
all GPIO Pins are deactivated.
kernel-module-sc16is7xx ... is installed.
i will need to take a look and do some research with the overlays. seems that i need a sc16is752-spi1.dtbo in /u-boot/overlays/
xell1984 avatar image xell1984 xell1984 commented ·
And it need WiringPi, which i don't get installed, as it is not in the package.
bathnm avatar image bathnm xell1984 commented ·
WiringPi will help with debugging GPIO issues, but is only one way. Looking at. the standard /etc/venus/gpio_list file it is not using GPIO pins 24 or 25 for anything. Further domes is not showing any attempt at starting the module. So it looks like it is an overlay issue. I would get a fairly recent PI Linux distribution and copy the overlay file out of that and put it on the VenusOS SDCard under /u-boot/overlays/.
The driver (sc16is7xx.ko) does seem to be included in the standard VenusOS build. So my guess is no overlay to help the system detect the interfaces.
xell1984 answered ·
@Bathnm
i will need to take a look and do some research with the overlays and the kernel model. Don't know exactly what it is, but i hope to find the solution. Thanks!
seamaster avatar image seamaster commented ·
@Xell1984 Did you get it working? I have the same one and I would like to get it going
xell1984 avatar image xell1984 seamaster commented ·
@Seamaster
No, tried it but bought now a Cerbo and Victron cables.
seamaster answered ·
tank you for the quick replay. Im struggling to read other NMEA2000 deices on the system. I see tanks, but biting else shows up. i have some N2K temperature sensors but they don't show up. Have you tried any of that with the can hat?
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
