mswoboda avatar image
mswoboda asked
LiFePo4 4batteries in parallel
I want to use LifePo4 batteries in parallel.
I will use a Chinese model which are able to "talk" to VE.Can bus. I think they are using the Pyontech protocol.
Suppose I will use 5 batteries with 48V and 230Ah and the BMS can handle 200A charge and discharge.
So the question is: What is the maximum Amperage I can charge and discharge with 5 batteries in parallel?
Kirchhoffs law says that the current is reduced in a parallel circuit:
As all batteries will be parallel, theoretical I could use 5x200A = 1000A, but in reality its too much, isn't it?
One company gave me a formula:
n...number of batteries
n x 200A / 2 = Max A
This would be 5 x 200 / 2 = 500A
What is the experience of the community?
I am happy with any answer!
Lithium BatteryBMScharge current limit48v battery
@mswoboda
Check you can run 5 in parallel. Alot of batteries can't.
But in theory you have "enough" amperage to run a 45kVa load depending on your current share in the set up.
How are you wiring it up? To a bus bar individually or looping them?
mswoboda avatar image mswoboda Alexandra ♦ commented ·
I will use Lynx.
You can use 15 batteries in parallel, thats what the producer confirmed.
The question is: What is the maximum of Ampere I can charge and discharge e.g. with 5 batteries (each battery has a BMS up to 200A).
The load of kW is a different thing. This has also to do with the inverters. But thats a different topic.
...or did you mean busbars between the batteries?
At the moment I plan to connect each battery with cables.
mswoboda answered ·
I think in the meanwhile I know the answer. Its better to build a busbar. Otherwise the batteries outside will be more used as the inner ones.
Battery Compatibility
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
