I'm trying to understand what the shunt is saying by reporting the battery at "Idle 29w". Wouldn't idle necessitate it being 0 watts since a positive number would mean charging, and a negative number would mean discharging?
There is just some hysteresis on what is considered idle.
I am not sure on the exact number but probably around +50W / -50W or some percentage of battery capacity.
Think efficiency and standby losses on the inverter. That's not reported, but it can be approximated and shown if you enable the DC Power tile. This might jump around a bit because the sample times of each component don't exactly coincide. There's a Widget for it in VRM Advanced, and you can get a good idea of the 'average' missing watts from that.
This assumes a shunt giving an absolute value to and from battery. For systems without the shunt, anything below like ~50W becomes neither-here-nor-there territory with respect to whether the batt is charging or not, so they've just called it Idle.
Idle means it is not exactly charging or discharging.
Either it is is full and PV is covering everything.
Or in your case... PV is barely covering loads (Including equipment) so it is not really charging.
If you dont have a shunt or bms connected the 29w is a calculated value.
It really is not charging at 26w.
Something is truckling in, true, but in bulk phase which you will be at that percent SOC is not a bulk charge.
How to change the Admin of a VRM installation
SmartShunt Installation Manual
SmartShunt Quick Installation Guide
54 People are following this question.
