alexander-aerts avatar image
alexander-aerts asked
PV inverter support assistant and DVCC
I have been succesfully using the PV inverter support assistant of a Multiplus 2 to control an external heater (excess solar energy dump in off grid system) via frequency shifting. My system had lead acid batteries.
Now I changed to Pylontech batteries. Charge control is now done via DVCC.
This caused the PV inverter assistant to stop working. I can configure the assistant, and as long as I don’t plug in the VE.bus cable of the inverter in the Cerbo unit, it works: ac output frequency is increased by Multiplus, as expected.
However, as soon as I plug in the cable, and thus establish communication with the inverter, the DVCC seems to overrule the inverter and PV inverter assistant stops frequency shifting.
Is there a way to make this work?
Thanks
Alex
PylontechAssistantsDVCCfrequencyHot Water Diversion
l81ker avatar image
l81ker answered ·
suggestion:
maybe you can try changing this setting to the opposite of whatever it is now in the ESS assistant
alexander-aerts avatar image alexander-aerts commented ·
Thanks for the suggestion, Never studied ESS as I understood this is for grid connected systems whereas mine is off grid. But I’ll take a look.
In the meantime I circumvented the problem …control of heater not using assistants any more but using node red via modbus.
