bm97ppc avatar image
bm97ppc asked
Add another MPPT by linking to the first via VE.Can (First connected VE.Direct)
OK, so I have a Multiplus GX and an MPPT VE.CAN.
The CAN port on the GX is used by the BMS. and the MPPT is connected to Multiplus GX using the VE.Direct
Can I add another by connecting the 2 MPPT together with VE.CAN, the original also still connected to the Multiplus GX via VE.Direct?
If that is not possible what are the options, as the GX only has 1 CAN Network and 1 VE.Direct Port?
Thanks
Multiplus-IIMPPT SmartSolarVE.DirectVE.Can
No, that's not possible, you need to use the VE.direct USB cable.
https://www.victronenergy.com/accessories/ve-direct-to-usb-interface
If the USB port is already used, you need a USB Hub.
bm97ppc avatar image bm97ppc commented ·
OK Thanks
