marten avatar image
marten asked
Mobile MultiPlus-II and SmartSolar setup
I'm planning a mobile marine setup and have some questions to those knowledgeable about this device.
In this context, can the MultiPlus-II be configured to seamlessly use the grid to assist the inverter during loads exceeding the capacity of the inverter?
Can the MultiPlus-II connect with a Victron SmartSolar charge controller via VE.direct without a GX device involved?
I assume that the MultiPlus-II can be used in a mobile setup, connected to the grid with a power plug where AC-IN L and N are occasionally shifted. I assume that the AC-OUT N/PE coupling relay will remain open while connected to the grid and the MultiPlus-II will remain indifferent to the actual AC-IN "polarity".
Due to the marine environment the grid PE would go through a galvanic isolator.
Thank you in advance.
Multiplus-IIMPPT SmartSolarVE.Direct
