k-o-hansen avatar image
k-o-hansen asked
Blue Smart charger and Smartshunt
I just bought a Victron Blue Smart Charger 12/30. It's installed in our solar setup to give some additional charging capabilities during winter months. The charger is hooked up to an digital gasolin generator.
The BSC is connected through our Victron Smart shunt. When the generator is running and the charger is going its thing. The shunt jumps straight to 100% SOC. Eventhough the SOC before running the charger was on 85%.
I'm running the negative to the BSC through the smartshunt. Is some kind of software setup I need to change?
The BSC is running stock on Normal 14.4v. And is showing Bulk.
My setup:
Batteries
520ah AGM batteribank 12v
Victron MPPT 100/30
Absorption 14.4v
Flott 13.60v
Blue Smart charger IP22 12/30
Charging voltage 14.4v
Smartshunt
Charged voltage 14.2v
Tailcurrent 4%
chargerSmartShuntVictronConnectvictron products
kevgermany avatar image
kevgermany answered ·
You have star synchronised on. This means that on connection/restart it will go to 100%. Stop charging. . Let the battery discharge for a while (SOC drops) and then charge. Should do the trick
k-o-hansen answered ·
Ok, so I don't need to do anything? Just let the SOC go down and then start charging again. Does it matter what the mppt is doing? Or the coexist and adapt when their on the same VE bluetooth smart network.
The BSC is added to a existing and working solar system.
Chargers.
VictronConnect Manual
Download for iOS / Android / Mac / Windows
SmartShunt Product Page
SmartShunt Installation Manual
SmartShunt Quick Installation Guide
SmartShunt Datasheet
