Lindsay avatar image
Lindsay asked
Grounding Battery's Neutral in ESS system
In Wiring Unlimited by Victron the ESS system's battery is grounded from the neutral (refer to image below)
Now I have a 3-phase ESS system using a Freedom Won 53V battery due to conflicting opinions, I'm not sure if I must ground the battery's neutral.
My connection is from Battery to Bus-Bars, Bus-Bar to circuit Breakers, Circuit Breakers to inverters.
Multiplus-IILithium BatterybatteryBattery ProtectGrounding
nickdb avatar image
nickdb answered ·
Please don't open multiple topics for the same thing. I will close this one, you can amend the original post as required.
