jamierob avatar image
jamierob asked
Can mppt load output terminals be controlled by PV voltage, or just battery voltage?
I've seen several questions on here related to this question (This, this, and this), but I'm still confused about what is possible. Is there a way to configure the load output terminals to turn on only when the PV voltage reaches a certain threshold, or can you only configure this based on battery voltage? My goal is to turn on a small pump connected to the load output terminals only when the PV voltage reaches 25v, and then disconnect that load when it drops below that threshold. I have a Smartsolar 100|20 mppt charge controller. Thank you!
MPPT SmartSolarVictronConnect
Alexandra avatar image
Alexandra answered ·
@jamierob
All the settings for the load output are battery related. See the manual here.
jamierob avatar image jamierob commented ·
Thank you. I thought that was the case but hoped I was missing something. I wonder what the cleanest way is of achieving this functionality with a secondary device. A relay, transistor, or even an arduino solution? I would be keen if someone had a simple solution for this.
albert avatar image
albert answered ·
You can use an arduino to measure the PV voltage. See https://create.arduino.cc/projecthub/manodeep/voltage-measurement-using-arduino-e91f5b
You can connect a relay to an arduino digital outout to switch the pump on and off. There are many examples, this is just one of them.
https://www.arduino.cc/reference/en/libraries/relay/
VictronConnect Manual
Download for iOS / Android / Mac / Windows
