Daniele Calabrese avatar image
Daniele Calabrese asked
Cervo gx how to connect 4 ve bus devicea
Hello
I have:
Cervo gx
Mppt for solar panels
BMV 712 for battery monitor
Smart shunt as DC meter for boat engine alternator
Ve bus to nma2000 cable
SD card
USB gps device
USB bluetooth for ruuvi
Multiplus 12/1600/4800
4 ultra capacitor batteries
Albicombi for engine sensors
Bilge pump sensor
Fuel tank sensor
Water tank sensor
Relay to turn Aircon on/off
Relay to turn lights on/off
Ethernet cable to connect to raymarine MFD and rest of raymarine system.
I now installed silent wind wind generator with hit own controller and i would like to add a shunt as DC meter selecting wind generator
How do I connect the 4th be bus device to the cerbo
Thanks
cerbo gxSmartShuntsolarvebuswind
pwfarnell avatar image
pwfarnell answered ·
I think you mean a 4th VE Direct device, you can get a VE direct to USB interface, if you run out of USB ports then you need a USB splitter.
Daniele Calabrese avatar image Daniele Calabrese commented ·
I did add the splitter USB so now I have a shunt connect as DC meter for wind and via ve/bus-usb however in advance I cannot see that to select widet for the data dashboatd I can see other devices shunt, mppt, usb-gps but not this device. something I need to do> thanks
Daniele Calabrese answered ·
so I can get a cable for the victron shunt ve.bus to usb and connect there? this one correct? https://www.victronenergy.com/accessories/ve-direct-to-usb-interface
pwfarnell avatar image pwfarnell commented ·
Yes, this is the cable to use.
Just be careful, you are calling it VE.Bus, it is VE.Direct. VE.Bus is what connects the Cerbo GX to the Multiplus.
thanks for the clarification and the advice
another question I cannot get the batteries to be charged to 100% here is the solar and here is the BMV config. what am i doing wrong?
one screen shot is solar the other one is BMV third is devices
Your settings look OK. Where are you located, solar will not provide a lot of power in northern Europe (anywhere at a similar latitude) at this time of year. If you are somewhere sunnier do you have a problem with the solar system, how much power are you getting into the batteries. The screenshot above shows it off, was that at night.
