Andrew avatar image
Andrew asked
Generator EasysolarGX 3kwa ii/250/70 with Pylontech
I am looking to get a generator to power the above for 2 x 3000 pylontechs This is for 2 freezers approx 200w per day,and other non load essentials at 1kwa/day. Any advice on the type and rating for UK on the generator? This is essentially offgrid and not possible to connect to mains.
Also suspect additional cables / fuses needed??
thanks
PylontechGeneratorEasySolar All-in-One
Alexandra avatar image
Alexandra answered ·
@Andrew
There is some guidance offered here when shopping for a genset.
Ideally you would want one that can run all the loads and charge the battery in a decent amount of time.
Andrew avatar image Andrew commented ·
@Alexandra thanks, genset was the missing info, will look
