dna avatar image
dna asked
Multiplus Compact 12/1600/70-16 goes in Alarm when connected to shore
Hello! :)
Hopefully you guys can help me up with the trouble shooting / config of my system.
It goes like this:
Shore -> multiplus -> 12V LIONTRON Lifepo
Also I am using a Smart shunt and a cerbo GX via VE.Bus. Firmware is 430.
The system is working fine, until I plug in the shore cable. Then the system shows the red alarm light an the following messages on the cerbo display.
Alarm - temperature high
Alarm - error temperature sensor
Alarm - battery low
The voltage is 13.11V, temp 29 C
When connecting the shore line, the voltage drops to 8.07V DC.
AC-line shows 95V due to the connected generator. Also it shows -1.3A, which I don’t understand.
Could you guys please put me on the right direction to solve the issue?
Thanks!
Temperature Sensoralarmshorepower
Mike Dorsett avatar image Mike Dorsett commented ·
Are you using galvanic isolation (transformer) for your shore connection?
dna avatar image
dna answered ·
CCE - Breaker circuit - easyplus (multiplus with breakers)
No additional isolation other than the built in in the easyplus
dna avatar image
dna answered ·
Some photos of the screen
Victron temperature sensor disambiguation table - which product supports which sensor
