gyzko avatar image
gyzko asked
IP43, syncronized charging and DVCC
I am looking for some details and/or confirmation about the IP43 charger 120-240V model.
When looking here,
https://www.victronenergy.com/media/pg/VE.Smart_Networking/en/ve-smart-networking-product-compatibility.html
it is specified that ONLY the 120-240V model supports both
  • the data sense sharing (V and T) capability
  • the charge synchronization capability
The 230V model only supports the first one.
Q1: Is the information found in the documentation accurate and up to date?
When I am looking to the change log of the IP43 firmware,
https://professional.victronenergy.com/downloads/firmware/file-download/?name=Phoenix%20Smart%20IP43%20Charger/Phoenix%20Smart%20IP43%20Charger%20firmware%20changelog.docx
the latest entry is about FW version 3.38. However, it looks like the 120-240V is only using FW 3.50.
Q2.1: Is it possible to update the change log document to know exactly what we have in FW version 3.50?
Q2.2: Is version 3.50 the initial release version for the 120-240 model?
Sometime ago, I posted few question regarding the IP22 rev2 and the synchronized sharing capability.
https://community.victronenergy.com/questions/99702/ip22-rev2-mppt-syncronized-charging-how-the-storag.html?childToView=100422#answer-100422
Basically, I will ask the same questions but for the IP43 (120-240V model only)
Q3.1: Does the IP43 120-240V model will always become the charge master if combined with MPPTs in a VE.Smart network?
DVCC vs VE.Smart network
In the VE.Smart network documentation,
https://www.victronenergy.com/media/pg/VE.Smart_Networking/en/limitations.html
it is said that DVCC voltage sense takes over voltage sense coming from VE.Smart network.
Let's suppose you have a system with an IP43 120-240V model and 1-2 MPPTs (being both VE.Direct and VE.Smart capable)
Q4.1: What about the "Synchronized charging" capability of the VE.Smart network when DVCC is enabled on the GX? Is it deactivated or still in function?
Q4.2: If it is still in function, does the current limit capability of the DVCC be used by MPPTs?
It is said here DVCC is not yet supported by the IP43 charger.
https://community.victronenergy.com/questions/144664/bms-ccgx-phoenix-smart-ip43-charger-the-dvcc-wont.html
Knowing the 120-240V model is using a newer FW (3.50)
Q5.1: Is it true for 120-240V mode? (.i.e DVCC not supported)
Q5.2: What is not supported exactly? Everything (voltage sense and current limit capability)? Or just the current limit capability?
Thanks!
-François
DVCCVE.Smart NetworkPhoenix Smart Charger ip43
nebulight avatar image
nebulight answered ·
Bump. Curious about DVCC and the Phoenix 50 amp 120-240v model. I'd like DVCC to control the charger that is controlled by my BMS. Doesn't seem to have a lot of info.
VE.Smart Networking Manual
DVCC chapter in GX manual
