Thanks Alexandra.
No I cant see It.
After reading manuals and making several attempts, the solution was much simpler than expected.
The new, original Ve-Direct cable was probably defective.
After changing the cable with a new one, the system was immediately seen by the Venux GX.
Being a new cable it was the solution that seemed most unlikely but it happened.
Thanks to all
Still glad there was a solution.
Make sure both devices have the latest firmware. Maybe there's something wrong with the VE.Direct cable? Can you try using VE.Can? Don't forget the terminator resistors.
I also tried an rJ45 cable in place of the Ve.Direct cable.
But the problem is still there.
75 People are following this question.
Large difference between solar blanket voltage output and Victron dashboard
SmartSolar MPPT 150/85 VE.Can - No current flow in Bulk with PV at VOC
Are 50vdc solar panels wasted on a 12vdc system?
Japanese RV Build— Stuck on Bulk / Configuration Review
MPPT 75/50 not reaching desired charge and float voltage levels
